valhalla360
Apr 07, 2016Navigator
dougrainer wrote:
You are absolutely WRONG. RV Absorbsion refers that have a 12 volt Heat Element are for in Transit only power. The 12 volt heat element will drain any battery bank in less than 8 hours. There is a difference between ABSORBSION 12 volt and a 120/12 volt RV compressor type unit. Doug Below from the Dometic manual.
Wow, that's what I said. It's way too inefficient to be a realistic option for full time 12v operation off grid.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
