dcook3333's avatar
dcook3333
Hello, Need a Laredo 274RB weight sticker image
Hello all! Just joined the forum. Thank you.
Anyways, as it says in the title, I'm in the process of transferring a 2015 Keystone Laredo 274RB into PA. The tag service says they need a picture of the weight sticker but.... this one is so badly sun faded that it cannot be read! I've reached out to the manufacturer but thought I would try a forum in case I get lucky and someone had one they could share. Thank you.
Dean
Oh, and if you have a photo of the tire sticker... I believe it would just be the standard 60lb as the tire pressure, too.
  • Look inside/on the back of cabinet doors as well.
  • I have found that info in the strangest places, mines on the outside like normal, there is another one on the inside of the screen door.
  • Have you tried submitting a picture of your faded sticker? The sticker is what it is. It may be inconvenient to them, but that's the sticker you have.
  • bgum wrote:
    6310 1490 7800 780 pounds per search of internet and specs
    Yeah, that is what I found.
    Problem is OP may have difficult time convincing the Notary they are using to use those numbers.
    PA is a bit nuts when it comes to this information.
    PA title must contain not only VIN, manufacturer name and build date but things like Unladen weight and GVWR.
    Most out of state titles/paperwork do not contain Unladen weight and or GVWR..
    GVWR is also needed to establish what the yearly registration cost will be, the higher GVWR the higher the cost of the registration will be..
    RV trailers Registered Gross weight of 8,000 lbs or less costs $12 per yr..
    8,001 to 13,000 is $35 per yr
    13,001 and up $90 per yr..
    Yeah, PA loves their fees..
  • 6310 1490 7800 780 pounds per search of internet and specs
  • Umm.. That WOULD be illegal.
    The weight sticker includes the VIN number and the VIN number IS what the "Tag service" is looking for.
    They need that in order to verify the VIN on the title paperwork you have MATCHES the VIN on the trailer.
    A 2015 trailer should also have a copy of the paperwork stuck to the inside of one of kitchen cabinets, did you look there? I recall quite a few yrs ago that the manufacturers were required to add that paperwork due to the fact the nearly every sticker stuck to the outside fades or disappears over time..
    Barring that, the VIN should also be physically stamped into the tongue frame or a plate with the VIN should be attached with pop rivets to the tongue. If so, take your trailer to your local Notary that handles PA tag/transfer services and they can verify the VIN matches.
    Amazingly so, myself, I have never ran into a Notary that has ever wanted a photo of that sticker or even went out to the trailer or vehicle to verify the VIN matches the paperwork..
    Perhaps find a different Notary?
    On edit..
    I guess that some states may not have the unladen weight and GVWR on their titles like PA, that also can cause an issue since they will need that in order to fill in the paperwork correctly.. See if they would accept a weight ticket from a CAT scale for Unladen weight.. GVWR? That would be a guess at best..
    According to Keystone website for your model, GVWR is 7800 lbs.. Dry weight will vary greatly due to manufacturing differences and options.
  • You need to get the one for your vehicle as it should be as your rig was assembled.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
