Rock2's avatar
Rock2
Help -- Suburban water heater - gas valve
The model # I have is SW10DE and serial #064211119. The valve part # is 161109. Before I order a new gas valve, I want to see if mine needs to be replaced or not. Valve has 4 terminals. I used electric multimeter to test ohm - terminal number 1 and 2 show no ohm while number 3 and four shows 42 ohms. So my question is my gas valve bad or not? I will be waiting to hear from you soon. Thank you!
  • Just a thought. This will be second time replace gas valve. Made me think it is possible that hot water dripping cause the coil short life? The last time I replace was nine years ago.
  • RV Sam wrote:
    The one closest to the tank usually goes due to high heat from the tank. Make up a little shield from a pop can or something to slide in there to reflect some of the heat away. Keep your old one as one coil is still good.
    Yes glad you suggested about save the old coil for spare. Will do that.
    That and water from T&P Relief Valve dripping on it.
  • The one closest to the tank usually goes due to high heat from the tank. Make up a little shield from a pop can or something to slide in there to reflect some of the heat away. Keep your old one as one coil is still good.
  • Thank you! Enblethen and Old-Biscuit. I think it is better to buy gas valve complete rather than kit. It is not much saving. Found Ebay. I am going to order today so hopefully get before weekend.
  • Based on your ohm readings the one solenoid is bad (Terminals 1-2) and one solenoid is good (Terminals 3-4)
    Need BOTH solenoids to open/keep open gas valve
    Your gas valve part number 161109 is a White Rodgers Gas Valve
    Replacement solenoid Kits are available.......much cheaper than replacing gas valve
    Solenoid Info
    Kit
  • Yes, you have a bad coil. Some locations have replacement coils, thou hard to find. Gas valve complete unit is better way to go.
