AlexESL
Jun 13, 2015Explorer
Dakota98 wrote:
I see a diagram directly behind the connections in the pic. Does that not tell you where the 12 volt Positive & Negative is ?
Also, make sure your + is fused to the fans.
Are you going to use a thermostat for the fans ?
Here is the wiring diagram, I found it
Wiring Diagram
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
