lil_camping_fam
Apr 11, 2015Explorer
If all of power is lost start at the source then work away. Like it was mentioned, check all connections including the ground (should be white for 12volt). The ground typically goes right to the chassis from the batteries or from the fuse panel. even if the connection to the chassis looks good, take apart and make sure there is bare metal between the termination points. I would also put some deox or dielectric grease to cover the connection.
Hope this helps!!
Hope this helps!!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
