Vulcan_Rider
Apr 11, 2015Explorer
Thunder Mountain wrote:
I turned off the house battery disconnect switch in the battery bay and turned in back on and everything is working.
Well that sounds like the "switch" is also a circuit breaker maybe.
I suggest that you (every RV owner) needs to carry an inexpensive multimeter with them. I also have a little meter I plug into one of the 12 V outlets to keep a constant eye on the volatge.....both when charging and when not. Those are available at CW.
And lastly, as someone else touched upon.....IF the coach batteries really are 8 years old, they probably need replacement.
You are checking the electrolyte level occasionally and adding distilled water as required......right ??
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
