catkins
Jan 02, 2016Explorer III
HELP - solar controller (monitor???) failed
I have Blue Sky IPN - ProRemote installed inside the RV for ease of checking status. Literally touched it tjis AM, saw a spark fly the around entire unit and now have a zapped dead panel.
So sitting on the desert worried about overcharging,. I have two Blue Sky Solar Booster 3024i controllers installed in the bay.I BELIEVE these actually controll the battery charging and the inside unit is simply a monitor?? Can anyone verify if my thinking is correct. I know just enough to be a bit dangerous...............
I am concerned that I not overcharge the batteries. Will monitor and turn off solar input if it gets too high but wanted the check the wisdom out there.
Thanks in advance
Thanks in advance
