zette
Aug 11, 2026Explorer
Help...
I have a 92 thor pinnacle q340 . I can't find where my ATS box is located. Please someone tell me?
Are you sure you have an ATS? Many RVs into the 90's used the shore power cord to plug into the generator. You plug in your shore power to a pedestal or into your generator. "if" your RV has an ATS, it would be in the bin with the generator or an adjacent bin. It needs to be pretty close to the power source. How long have you had this RV? Are you having an issue and if so explain it. It may not be your ATS. No power with the genny running could simply be the breaker on the generator itself. The more details you provide, the easier someone can try and help you.
My generator fell and I lost my 110 power I have power going out the outside pedestal but nothing working.all breakers and fuses are good
Still pretty cryptic. What do you mean "fell"? As in physically fell out of the RV? Due to rust, frame failing? If that happened there is likely a host of electric issues it tore in the process. Almost impossible to armchair diagnose this. If your supporting structure is bad enough to allow the generator to fall out of the RV, then I would guess there is a lot of corrosion or physical damage and wires and grounds etc. are not getting good contact if at all. This is all a guess because you haven't provided any real details. I would recommend calling an RV tech to come take a look at it.
