MrWizard
Oct 05, 2014Moderator
batteries don't recharge by themselves
you use 12v power you have to charge the house battery
single battery you should charge everyday..
don't wait for everything to quit working, your killing the battery so that it won't recharge to full power
you can plug in to recharge
you can run the engine..it will recharge if the wiring is correct
you can buy a generator to use instead of campground power
but you must charge that single battery "often"
you should get the info from the converter
thats the box with the circuit breakers and the 12v fuses
and post it here
we can tell you wether or not you might need to get a automotive battery charger to do a faster recharge from generator power
and post it here
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
