Hurricaner
Oct 06, 2014Explorer
If the lights are working than the battery and converter are too. You need to locate the 12 volt fuse panel and check the fuses. I suspect the one feeding your heater and water heater are blown. The panel should be fairly easy to find as they usually don't hide them.
Sam
Sam
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
