Golden_HVAC
Aug 13, 2013Explorer
grodnay wrote:
BTW the MH has 40000 miles on it...
With that low of mileage, the transmission is not likely to have worn out bands, and bent something or another inside it. However any AMMCO transmission shop will be happy to install a newly rebuilt transmission for a few thousand dollars. They might even claim that they disassembled the transmission, and show you some overheated and bent and worn out parts (likely have been sitting in their shop for several months.) Of course some transmission shops are better than others.
If you knew a honest repair facitily, recomended by a member who lives in the Las Vegas area, they can change out the front seal, and get you on your way. That new seal might last 5 years or so.
With such low mileage on your RV, I would suspect other seals are going to start dripping too. I had my rear axle seal leak at around 25,000 miles, and had it repaired. My extended warranty covered the cost of the leaking seal, however the rip off RV dealership that handles my warranty and sold me the RV wanted over $500 to install replacement brake pads while repairing the seal. I installed new ones for $75 myself, after finding a friend with a 3/4" impact wrench that could take off the way overtightened lug nuts.
So I would not hesitate to replace just the seal. What they will have to do is remove the transmission, take the torque converter off the input shaft, dig out the old seal, and install a new one. Then slide the torque converter back on, re-install the transmission. Something that you can do in your own driveway, but much easier to do on a lift, with a transmission jack to handle the 300# weight of the transmission. Shop time should be in the 4 hour range.
Fred.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
