BFL13
Dec 09, 2019Explorer II
Nomadlyweds wrote:
Thanks to all for the suggestions -- seems like conditioning is the right answer, I'll give that a go.
I do have a Victron charge controller with temperature compensation.
You normally can't do it with solar, because it gets dark too soon and the voltage falls off.
That is why you normally need a charger that can hold 14.4ish volts indefinitely until the amps get down to 0.5/100AH.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
