grizzzman
Feb 15, 2017Explorer
Rbertalotto wrote:What profile do you have it set on?#9battery temp reading66cwhat is your P8 setting? And P1?I'm not sure how to access this. I'll need to look at owners manualAny chance you accidentally turned equalization on?How would I have done this?
Update: I disconnected the solar panels and waited about 15 minutes. Reconnected and everything was back to normal. But the sun was getting lower in the sky and I'm not sure if this wasn't the reason. Will see what it does tomorrow.
So your batteries are at around 151 degrees Fahrenheit ??????????? Are you getting the reading off the TM2030?
Press and hold the upper button when you see P1 press again for P2 etc
