azrving
Feb 15, 2017Explorer
Rbertalotto wrote:What profile do you have it set on?#9battery temp reading66cwhat is your P8 setting? And P1?I'm not sure how to access this. I'll need to look at owners manualAny chance you accidentally turned equalization on?How would I have done this?
Update: I disconnected the solar panels and waited about 15 minutes. Reconnected and everything was back to normal. But the sun was getting lower in the sky and I'm not sure if this wasn't the reason. Will see what it does tomorrow.
Ok so you have Concord?
66c is 150 f. Something wrong there. It's not in F as it oly reads Celsius I believe.
P is accessed by holding the button longer. As you hold select it will show AH and then P. When you see the P let go of the button and then scroll the P menu all the way through P22. If you hold it even longer you will go past P and see H history menu.
Equalization is turned on by holding select until AH shows and let go of button. Then scroll past ah and days since charged and you will see days since equalized. Hold reset and it will zero out days since equalize. Then hold reset again and it will flash equ 3 times and then lock on to equalize.
