azrving
Feb 15, 2017Explorer
Rbertalotto wrote:
Batteries were not even warm to the touch. I must have read the number wrong. I just reset the simple parameter to #18 for a Generic AGM battery (Duracell Group31)
The #18 setting has max charge of 15v
Now set to #18 I can no longer see temperature or solar output when cycling through "select"
Did you lock on to setting 18?
Yes it has 15 as max so that low temp charging can occur. voltages will be higher at low temps.
If sun is down and you are not charging, the top light will be flashing and you wont be able to read solar input or temp. When charging top light will be solid. When not charging and you scroll the ah menu (2nd one in) you will go from rpc all the way back to main menu and battery voltage will appear.
