azrving
Feb 15, 2017Explorer
The instructions and the part about what I call "locking on" for setting p22 are on page 8 of the solar controller manual. It's the part where it counts down 5 4 3 2 1
As I mentioned earlier, if you disconnect the sc2030 from the trimetric it will work as a basic function solar control and with the switch set at agm it should only go to 14.4 I believe. There is also a switch on the controller for 12 or 24 volts system
