wa8yxm
Jul 03, 2013Explorer III
Well, that LOOKS like the exact same hose I use, only mine is a Marshall brass.
NOW,, I have worked on a Mr, Buddy heater that did not work off a luggable tank.. Turns out it's the hose's "Quick Disconnect" the valve pin inside it is not long enough so you need to screw it into the regulator very very very tight. I had to use tools to get it tight enough, then it worked.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 26, 2026
