GordonThree
Aug 24, 2020Explorer
way2roll wrote:GordonThree wrote:
Is the quick connect on the high or low pressure side?
Might need to modify your grill, depending.
Good question - unfortunately I am propane illiterate and have no way to answer your question. :-)
All I know is, it's a line that comes from the regulator, down beneath the trailer to a quick connect.
Sounds like low pressure. Might want to wait to buy your pigtail until you find out what connection you're left with on your grill when you remove its regulator. Likely you'll be working with a plumbing fitting, and not a propane tank connector.
My Weber Q1200 for example, the regulator threads into the gas valve, so the regulator (which has the propane fitting) can be removed, and a quick connect receiver installed.
Having RV issues? Connect with others who have been in your shoes.24,395 PostsLatest Activity: Jun 23, 2026
