naturist
Aug 24, 2020Nomad II
The quick connect on your rig is indeed a low pressure line. The male fitting was about $7 last time I looked. You need to remove the regulator on the grill. Any RV dealer should have the pieces you need. Do be aware that between propane and compressed air, there are at least 3 visually identical but totally incompatible quick connects.
Having RV issues? Connect with others who have been in your shoes.24,395 PostsLatest Activity: Jun 23, 2026
