JeremyR
May 27, 2021Explorer
sparkydave wrote:
Just spitballing, but if the noid light got brighter when it started running on ether, I wonder if there could be something wrong with the crank pickup sensor. That should be triggering the ECU to fire the ignition and/or fuel injectors, but it seems odd that once the engine spins faster the injectors apparently are getting driven harder. Your battery voltage is still staying at a healthy voltage while cranking, yes?
Noid light gets brighter as engine RPM goes up from my understanding
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
