dougrainer
May 18, 2022Nomad
1. What KIND of digital thermometer? Did you place the Thermometer in a glass of water that had been in the refer 24 hours without opening the doors? There is NO WAY your freezer read -15 degrees. That -15 is interpreted as BELOW 0 degrees by 15 degrees. Or do you mean the temp was 15 degrees?
2. I hope you did not use a IR thermometer. These will not give correct accurate temps for refer readings
3. There is NO temp adjustment on RV refers for the freezer. The Temp system only adjusts the lower refer section and since you have an adjustable temp setting do not worry about the slider on the fins. Moving the slider is an option for Auto temp refers that have NO adjustable tstat. And that only changes the set temp by about 4 degrees.
4. Your normal temps shopuld be 0 to 10 degrees in the freezer and 28 to 36 in the refer.
5. Is it possible you were not completely level when loading up? That would degrade the ability to cool correctly. Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
