BurbMan
May 18, 2022Explorer III
I appreciate the help guys! Yes an IR thermometer is not the most accurate but was enough to confirm I have a problem. I installed the AccuRite wireless fridge and freezer thermometer and it's confirming my readings. Amazon same-day delivery is a great innovation, but save that for another post. Ordered at 10 am and was delivered by 1:30pm.
I set the fridge to "GAS" and dialed the temp control up to "5".
I double checked the thermistor, and this is as far as it will go up on the fin:
Here's the readings I'm getting on the Accurate sensors after being installed for about an hour. These were close to the same readings I was getting with the IR thermometer (the -15 must have been wrong, Doug).
So it looks like the cooling unit is bad? I thought switching over to gas would rule out a weak heating element but that doesn't appear to be the problem.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
