dougrainer
May 18, 2022Nomad
pianotuna wrote:
Sometimes taking the fridge out and rolling it end for end and side for side may free the blockage.
Wives tail. The blockage is as hard as a Weld slag. What you stated is called "burping". WILL NEVER FIX A REFER BLOCKED COOLING UNIT. But, what is can do is "rearrange" the Ammonium liquid to temporarily bypass the blockage but will only work partially for a few days to a week. Once the blockage stops the liquid again the refer stops cooling. Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
