pianotuna
May 18, 2022Nomad III
dougrainer wrote:pianotuna wrote:
Sometimes taking the fridge out and rolling it end for end and side for side may free the blockage.
Wives tail. The blockage is as hard as a Weld slag. What you stated is called "burping". WILL NEVER FIX A REFER BLOCKED COOLING UNIT. But, what is can do is "rearrange" the Ammonium liquid to temporarily bypass the blockage but will only work partially for a few days to a week. Once the blockage stops the liquid again the refer stops cooling. Doug
Hi doug,
Pray tell us why it worked for BobsyourUncle?
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
