rsqfyrmedic's avatar
rsqfyrmedic
HELP! Honda2000's in parallel overloading....
Hi all....tried to "boondock" on the side of the road and one of my 2 Hondas keeps overloading and shutting down. I'm using the Honda parallel kit wired into a standard 30amp receptacle/box made for Champion generators.....gotta check but I'm pretty sure the wires for the connections inside the box were also 10gauge. The ref is set to gas, single 2000 will run the 15k a/c but nothing else. Last night we were able to watch TV, dvd player and plug in cell phones when we started having the problems. I'm also using an extended run fuel tank. Should that be vented to the "open" position on the gas cap? When the genny shuts down I turn the switch off and back on, unscrew the gas cap a bit (hear a little hiss), then start....sometimes I need to choke it but it sounds fine. A few minutes later it will overload and shut down.
Here's a quick pic if you see anything I may be missing...
Thanks in advance for all your help
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
