RoyB
Mar 19, 2016Explorer III
Until you get you propane heater fixed you need to go down to LOWES-WALMART and pick up a 120VAC OIL-FILLED heater. These are inexpensive... You should have a couple of these on hand for PLAN B anyway...
I also carry an extra HD extension cord just for the heaters. This allows me to use the 20AMP SERVICE from the campground pedestal just for the heaters. Doesn't take away anything from my 30AMP shore power hookup.
I use the low profile oil-filled heaters (AMAZON) but the taller ones are OK as well... Both put out the same amount of heat.
I can sit one of thes O2COOL AC/DC/D cells portable fans (WALMART) behind the heater if we need to move the air around the room more..
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
