3_tons
Jul 01, 2018Explorer III
Questions:
Is your inverter wired to power up the camper’s onboard converter charger too?...IF so, that would be a path to supply the 12v side of things...
Also, Battery cabling to inverter should be dedicated for inverter only and of heavier AWG gauge...Battery cabling to camper’s 12v fuse panel (via the cut off switch) is separate from inverter..
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
