TakingThe5th
Jul 02, 2018Explorer
MEXICOWANDERER wrote:
Was the onboard battery down at the corner saloon during all this?
Audit every single terminal and every single device between the onboard battery and the fuse panel.
INSIDE THE INVERTER is an automatic changeover relay that provides power to the CONverter get it? The INverter is Dick-Smithing the battery and providing AC power to the CONverter. You are seeing power from the CONverter. This is exactly like what government does with your taxes.
X2. Also you could have a broken battery post, an internal break in the battery. A long shot, but "Hanging" your battery by some short cables or "coaxing" a stubborn cable off the battery could cause that problem, amongst other reasons. Wiggle the posts.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
