MEXICOWANDERER
Jul 01, 2017Explorer
SIDE NOTE
Go online, perhaps to eBay or Amazon.
Find a good looking 12-volt rated LED pilot lamp, and configure a way to have a stylish bracket for it. My personal choice is a blinking 5mm green chrome bezel LED.
If the inverter fuse should ever fail, the blinking light screams at me "FAILURE!" So I do not need a flashlight to check fuse integrity at night.
Wiring the LED is child's play. There will be two long wires extending from the LED. One red the other, black.
Connect the RED wire to the BATTERY side of the fuse
Connect the BLACK wire to the INVERTER side of the fuse.
Quicksilver has Klixxon toggle breakers. Every 12 volt breaker has a 5mm red LED wired across it and every 120vac breaker has a 5mm blue LED wired across it.
I open the panel and don't even have to "look".
The main breaker has an LED has well.
A product of being incredibly lazy.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 30, 2026
