DiskDoctr
Jul 01, 2017Explorer
BFL13 wrote:
...If you get the Trimetric, you will need its 500a shunt, not the little 100a one. (IMO just bite the bullet and get the Tri instead of fooling around with cheaper kinds that can't do it all)
$200 :(
Eventually may build out Arduino, but looking for something to get started. If we can find a decent hall effect ring in this amperage, I'd be happier to use it. If we go over the amps on it, there shouldn't be any damage to the sensor, right?
The inverter really wants direct cables to the batteries, according to all the installation docs I read. Make sense ?
Same with the converter/charger, then branch to the frame lug and feed to the camper/distribution box.
It may not be "ideal" but should be fine, right?
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 30, 2026
