pianotuna
Jul 01, 2017Nomad III
Hi,
My system evolved over time. I started with a 70 amp ammeter and voltage was displayed on my Blue Sky charge controller.
I don't prefer the Trimetric as it requires you to set the battery capacity (capacity is a moving target, dependent on load and state of charge, among other things such as temperature) and it doesn't do a Peukert Calculation.
That said BFL13 makes good use of his trimetric. I would not have the patience to do so.
If you must have an amp hour counter, the Victron units are cheaper and a little more accurate.
If money is no object then look at the Smartgauge unit.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 30, 2026
