BFL13
Jul 01, 2017Explorer II
Your exact resting voltage for the 6s will be in their specs. Trojan says 12.1 for theirs, eg. However you will be camping so they are not really resting. You just take the voltage when nothing much is on and that is close enough. The idea it to do it the same way each morning so you get your daily drop for predicting.
You are going to recharge at some point either over or under exact 50%. No point in getting it exact.
With solar, you need to take your morning voltage before the sun gets the voltage up, making it look higher than it is for the actual SOC.
You are up at 5 anyway, so that's no problem. :) Sure.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
