evy
Apr 01, 2016Explorer
Almot wrote:
Grease and spatter WILL go all over :)
The best you can do is to make the surrounding wall easy to clean. Wallpaper is relatively easy to clean if you do this every time after using a stove, but who does? I'm thinking of getting a piece of cheap laminate on the wall - you know, those fake tiles sold in big sheets. One of those projects that might never materialize. Will paint the wallpaper when it gets too ugly, I guess.
The counter is plywood but I will cover it with Formica
I will do the same thing with the backsplash around the sink (behind and on the side)
As for the grease splashing I could simply get one of these cover and also add some counter top space when not using the cooktop...
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
