pianotuna
May 20, 2016Nomad III
Here are the requirements:
800 amp-hours of LI with nominal 48 volts
1600 watts of panels with a PT-100 Magnum charge controller
4400 watt 48 volt Magnum hybrid inverter/charger
A 48 volt dc to 12 volt dc converter to handle the 12 volt needs.
Nice but none essential:
a 48 volt element for the water heater to use up solar on those days when the air is not needed.
A back up generator--with the hybrid inverter even a 1000 watt generator could power the roof air--but I'd probably go with a 2000 watt.
enough unshaded roof space to install the panels, or create a roof rack that goes above the air conditioner shroud so the panels are totally unshaded. Tilting would be preferred.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
