time2roll
May 20, 2016Nomad
Both the panels you stated have 60 cells and are 24 nominal panels. Will work fine with the MS MPPT controller.
A few 24v panels have 72 cells and the higher voltage will dictate more parallel than series. You can get controllers up to at least 600 volts if you really want to do it all in series. There is a modest loss of controller efficiency as the conversion grows wider.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
