grizzzman
May 20, 2016Explorer
pianotuna wrote:
And you need to count the cells in each string of the panel. Or look at the specs.grizzzman wrote:pianotuna wrote:
Each cell on a solar panel produces about 0.5 volts. 250 watt panels may not have a greater cell count than 150 watt panels, so the output voltage would be the same. The amps on the 250 watt panel would be greater.
You need to do you're homework. This shows that you don't understand the difference between panels.
Looks like "I" need to do my homework. I apologize
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
