rk911
May 27, 2015Explorer II
Hvymtlc5 wrote:
5 year old Dometic 2862 (A/C n /LP). If the unit works fine (freezer/frig) on LP then the cooling unit or thermister cannot be bad because these are used by the 12V LP system too - correct? There must be an issue elsewhere?
I have checked 120V power to the heater from the board and it is there and element ohmed fine and is hot. Fuses are good. Cooling fan is running. Trailer is level. Power is stable. Freezer is cold, frig/fins are not cooling at all. Black tubes on back of frig are very warm..but not hand burning hot.
all I can think of then would be the control board. you may need a certified tech to diagnose that.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
