dougrainer
May 27, 2015Nomad
I think you made a mistake on your problem. You stated that it works on LP, then stated 12voltLP system. THAT is the same power source. Do you mean it does NOT work on 120ac power?. You only have 2 sources of HEAT---LP flame and the 120 heat element. If it works on LP just fine but does NOT on 120 and you are positive the Heat Element is HOT and working, then the only other 2 problems it can be
1. The LINE voltage is below 105 volts. What is the line voltage?
2. The sleeve the Heat Element is in has slightly/or detached from the burner flue(very rare). IF this has happened on a Dometic, there is a 2nd unused heat element sleeve next to the original and you just pull the element and install in the extra sleeve. Doug
PS, have you waited 24 hours?
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
