- BootScooterExplorerI did mark all the wires from the old unit and all the ac and dc power is dead!
- BootScooterExplorerThanks for your replies!
- BootScooterExplorerOn the DC side there are 2 red wires on the 1 and 2 fuse block where do I connect the red wires
- Welcome to RV.net!
Changing out these two units shouldn't be too bad if you have some electrical back ground.
It should be fairly simple.
Disconnect battery and shorepower. Make sure the circuits are truely dead!
You will need to identify all the circuits and wiring. Mark them good with tape and marker. Take photos as you go.
Locate the 12 Volt DC wiring. Identify them. Take photos.
Manual looks pretty clear.
Manual - Mandalay_ParrExplorerDo you have an electrician friend that can help you?
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
