Mandalay_Parr
Dec 30, 2013Explorer
Regardless of who says what, you have an electrical problem if the GFI trips.
Suggest you get an electrical person to help you. Several conditions can cause it.
I have seen where the the MH was not properly wired causing such a problem. It had the neutral and ground wires connected together at the power distribution panel.
Suggest you get it corrected whatever it is.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
