dougrainer
Nov 16, 2022Nomad
Is the WH in a slide room? Also, oily build up in LP systems can cause a problem on just 1 appliance, if that is where the oily build up happens. Also turn on the Range LP burners on HI. Then start the Gas furnace and see what the range burners do. They should not pulsate or diminish. If they do, your LP regulator is bad. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
