rvexodus
Nov 18, 2022Explorer
Ok problem solved. Tried the reverse burp procedure above and that did not resolve it. I did however tap on the pin the operates the valve via the little flip up handle and simply tapping on it seated the valve enough to slow down the drip. This told me it was just a little corroded / gunned up. Could have possible cleaned it in some vinegar but had already received a replacement valve and decided to replace it. Drip drip is gone and since there’s no more water dripping on the 12v solenoid leads the flame hasn’t had any issues either.
Doug, thanks for your feedback and willingness to help. Keep up the great work. Folks like yourselves are invaluable.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
