dougrainer
Oct 06, 2013Nomad
Monkeyrun wrote:
Where is the cold air return on these units? Si that it on the top as seen through the hole in the floor via last picture?
Thanks for the help on this one folks!
Regards,
MR
The cold return for the rear furnace is that access door you removed to show the duct hoses.
The cold air return (front) is both that hole in the last pic you posted and the area inside the basement where it is mounted. Doug
