MEXICOWANDERER
Jun 06, 2019Explorer
So you can siphon at various places ans get water?
I've seen inside hose liners peel loose. At various suction vacuum they will plug a pipe or remain open. Same for domestic water inlets beyond the pump. You don't have any kind of pressure limiter after the pump? I've had to disconnect the SUCTION side of a pump and blow air backward into a tank to diagnose a few screw-loose problems. Must hear tank boil with air bubbles. Assume nothing. Test :)
