skipnchar
Jun 12, 2013Explorer
Without the by-pass line you will not be able to properly winterize your RV using antifreeze. You will have ZERO water to the hot water lines without the bypass line. If you winterize before closing off the water heater then you will need to use an extra amount of antifreeze to fill the water heater before winterizing the hot lines. If you remove the lines you will STILL have two fittings and THEY can leak (much more likely to leak than the PEX tubing is). I'd leave it alone and use it as designed but it's your call.
Good luck / Skip
Good luck / Skip
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
