enblethen
Nov 09, 2015Nomad
Check the lamp configuration. It could have the wrong lamp and is shorting out the circuit. Look into the socket, check to see if it has a single or double pin. Lamp should be the same configuration.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
