jeffwhite
Nov 09, 2015Explorer
Chris Bryant wrote:
A lot of wall sconce fixtures use a 1076 bulb, which has dual contacts on the base- hot and ground, rather than the standard single, ground through the base type. The wrong bulb will result in a short.
MrWizard wrote:
sounds like a short to ground, at the light fixture
defective fixture, wrong bulb ?
is the bad fixture in a bedroom slide ? if so could be a pinched or worn wire
enblethen wrote:
Check the lamp configuration. It could have the wrong lamp and is shorting out the circuit. Look into the socket, check to see if it has a single or double pin. Lamp should be the same configuration.
Ding, ding, ding,ding..winner winner chicken dinner. Plugging a single pole bulb into a double pole fixture, ridiculous......Never even considered it. Thanks all. Gonna check out that "nuts and bolts, simpleton" troubleshooting link MexicoWanderer, thanks. jeff
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
