RoyB
Nov 13, 2015Explorer III
I like to stay with the 60AMP models as these units can easily be operated with my 2KW Honda Generator to re-charge my battery bank each day in a three hour generator run time using the on-board smart mode 60AMP converter/charger.. The larger DC OUTPUT converter/charger units might not work from the 2KW Generator output.
I like to have enough DC OUTPUT CURRENT AVAILABLE to support each battery in my battery bank general requirement of demanding 17-20AMPS DC Current when first hit with 14.4VDC to be able to go from the 50% to 90% charge state in a three hour generator run time period. My three each battery bank wired in parallel demands around 52-53 AMPS DC Current when first started up being charged with 14.4VDC - My PD9260C 120VAC Input watts spec is 1000WATTS.
My generator revs up pretty good doing this running my PD9260C converter/charger and then tapers back as the charge demand start dropping back as the batteries are taking on their charge.
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
