ewarnerusa
May 27, 2013Nomad
KJINTF wrote:
Just a suggestion .... Yes it will isolate the controller anytime the set point is acheived.
Might want to look into an inverter that can handle 15.5 Vdc or higher... The problem goes away
Thanks for the help, KJINTF. I think tweaking this sweet controller to clamp the charging voltage at 14.8V will be cheaper than buying a different big PSW inverter!
I know you have mentioned a few times how I'll want to use custom settings vs the standard algorithms, and now I am definitely finding a need to.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
