HiTech
May 27, 2013Explorer
Just another option - normally load disconnects are for low voltage, but it there a high voltage load disconnect? If there is you could use that to run a relay or solid state switch to disconnect the temp sensor, which would drop your voltage back in line. Might need a timer on it as well.
Jim
Jim
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
